No Reverse
K I did an LQ4 swap and am using my stock 4L60E and I have no reverse. Have hooked up the Tech2 and found my PRNDL switch shows the gear change. But the Trans Fluid Pressure switch shows Park, Neutral, Neutral, Drive4, Drive3, Drive2, and Drive1. Could it be in the valve body when I did a rebuild? PLEASE SOMEONE HELP ME WITH THIS!!! I need my truck back!!! My GTP spun a rod bearing so I haven't had a car for the last couple weeks and am sick of F'n walking!!!
- You may not post replies
- You may not edit your posts
