Results 1 to 10 of 15
Thread: noob turbo question....
    This will probably sound stupid but will 8psi on say a 5.3 make the same power as a different turbo but same 5.3 and 8psi?
    Mar 2007
    Newark, Delaware
    Nope.
    Ponca City
    That's actually not a stupid question. Go on pt.net and they have a very interesting post about psi vs turbo size. Worth the read
    Slowest in Oklahoma...
    Jan 2012
    DFW, TEXAS
    add volume too
    Mar 2011
    Gibbstown, NJ
    Quote Originally Posted by Beatdown Z View Post
    Nope.
    ^ Correct
    A turbo is like a fingerprint, no 2x are the same. Hence the different results each will yield
    2001 ECSB Z-71: 7.0L LS7, Kook's LT's, True Duals, RPM Tune, F.A.S.T. Intake/TB, YANK TT3000, 4:10's, G80, AWD Swap, 160-Stat.....
    Slowest in South Jersey ..........SOLD :-(
    2012 GMC Sierra Z71 CC: 6 Speed, 3:73's, G80, Back up DD...........SOLD
    2000 RCSB Shitbox.......370LSx/Built 60e/4.56's,EATON Posi, CAI,3" SLP Exhaust, DD.......Build Thread http://www.ls1truck.com/forums/my-ga...ker-punch.html
    Quote Originally Posted by MrHorsepowerLSx View Post
    ^ Correct
    I've read a lot about turboing engines, it seems more about cfm than psi, am I right?
    Mar 2011
    Gibbstown, NJ
    Quote Originally Posted by zane-O View Post
    You are definitely on the right track about that, but it must be a perfect blend of both CFM/PSI. You can't just go and cram 35psi down your motors throat without the CFM to back it up. You can't have one without the other
    Is cfm constant or does it vary any on a turbo?
    Sep 2012
    A motor is a big air compressor! The more air u get in an push out the better everything works. If it flows the more power you will make. That's all it come too! Air in air out!
