Page 2 of 2 FirstFirst 1 2
Results 11 to 16 of 16
Thread: Starting my first ls swap!!
    Aug 2011
    Mabank, Texas
    Quote Originally Posted by Slowcrewcab View Post
    Hey guys got the swap complete running and driving! Got to do some clean up work with the wires and stuff but ill take some detailed pictures of all that I can and list all parts used! This is a straight forward swap that almost anyone with mechanical skills could do!
    Awesome! My dad has a 78 we are wanting to do this too as well. we already have the 5.3 and harness, but just need the
    time to get started. Cant wait to see pics of the finished product.
    2002 Chevy Silverado 2500 HD. CAI, 4.10's, 35x12.50 r17 Kumho Road Venture M/T's. Nelson Tuned.
    2002 Z28 Camaro- Small budget cam build. Full bolt on, Custom grind Comp Cam, LS6 intake, 4000 CircleD stall, Nelson Tuned.
    2008 Dodge 2500- H&S MiniMax, CAI, DPF delete, EGR delete, AirDog fuel system.
    Feb 2012
    Mcalester ok
    Well swap is done besides few wires to clean up! As stated easy easy swap. Started by piling the junk motor and tranny together. Bolted the dirty dingo mounts to the new 5.3 and lowered motor in by itself. Left the mounting bolts loose on the motor mounts so I could adjust when installing trans to crossmember. Once trans was mounted I tightened the motor mounts and started the wiring. With the harness I used wiring was easy easy! Plug and play besides ECM hot wire, ECM ignition and fuel pump wire. Used a carter p5000 inline fuel pump that I believe isn't enough so ill be ordering a walbro before to long. Ran 3/8 fuel line from bottom of tank( was already tapped with jic fitting). As of running shirt in money a ran stock truck manifolds for the time being, had to notch frame on passenger side maybe 1/4 inch, ran 21/2 inch true duals to 40 series flow masters. Using the dirty dingo mounts I didn't have to have to alter nothing on drivetrain
    Feb 2012
    Mcalester ok
    Mar 2013
    Mount Gambier, Australia
    Sorry to dig this up, but I see you ran truck?? exhaust manifolds? I have just done a 5.7 GEN111 into my 1978 C20, and had to run headers as our manifolds out here would not clear the chassis rails. I think they are the same as your GTO manifolds.
    No truck type out here.
    Yours is looking good. Would like a 1986-7, but expensive out here.
    1978 C20 short bed pickup, GEN111, 4L60E trans.
    My truck is a 78 C20 and the 5.3 (2002) truck manifolds fit ok. Not great but ok. On mine I notched the drivers side frame rail a little bit to clear for engine vibration.
    I have stock headers from an LS1 and they are MUCH different than the truck manifolds. They will not fit in my truck.
    Quote Originally Posted by Gen3 Cheyenne View Post
    Long week... Mine is a 1973, not 78... Damn time for the weekend already..
