Results 11 to 20 of 23
Thread: Long travel pre runner 4-linked!
Threaded View
    Sep 2010
    San Antonio, TX
    This is a friend of mines truck, just thought I'd share. I helped him build the truck so I can answer most questions.
    Huge price drop.
    $13,500
    I'm selling my 2001 Gmc 1500 Prerunner!! I hate to see it go but I'm moving on to the next project, and just can't afford to keep all the toys. This truck is in great running shape, its got a ton of power and everything in the drivetrain is new! It is a very sound truck, and the suspension preforms GREAT!! This truck has a couple dings on the cab but nothing to bad... It does have 208,xxx miles on it, but has had exceptional maintenance done on it, as far as regular oil changes. This truck definitely speaks for itself, and definitely holds its own on and off-road!!
    Here's a fairly detailed list of parts I put on to make this awesome Prerunner:
    Engine(4.8L 294c.i)(dyno'd @311rwhp/301rwtq) which is almost 400hp @ the motor
    4.8L w/ 208,XXX miles w/ exceptional maintenance
    Oil changes regularly using Mobile 1 full synthetic 10w40
    Texas Speed 224/224 .581/.581 112LSA cam
    Comp Cams 918 valve springs w/ chromoly pushrods
    Pacesetter Long Tube headers
    Dual 3" exhaust x-piped w/ 18" MagnaFlow mufflers
    Spectre CAI
    Nelson Performance custom tune
    EGR and PCV delete
    Transmission(4L60E)
    Trans was built to withstand 600hp
    TransGo HD2 shift kit
    Yank SS4000 stall converter
    Valvoline Dexron-VI full synthetic trans fluid
    Rear End(10 bolt)
    Factory trussed 10 bolt
    Motive Gear ring and pinion (4.88 ratio)
    Eaton Trutrac carrier (brand new)
    All new bearings (carrier/pinion/axle)
    New Timkin carrier bearing for driveline
    Front Suspension
    J*IND custom Long Travel kit (bummed and strapped @ 16")
    Upper and Lower control arms are powdercoated "Gold"
    Spindles and tie rods are powdercoated "Satin Black"
    F.O.A 8" 2.5 coil-overs w/ Eibach springs
    New Timkin wheel bearings (both sides)
    All hardware for the kit is Grade 8 fine thread
    Engine cage made from 1-1/2 x 3 rectangle tubing
    Rear Suspension
    J*IND custom 4-link kit (bummed and strapped @ 18")
    F.O.A 18" 2.5 coil-overs w/ Eibach springs (dual spring rate)
    All hardware for the 4-link is Grade 8 fine thread
    Upper and Lower links are powdercoated "Gold"
    Custom bed cage (designed for optimum strength)
    Cage was made using 1 3/4 .120 wall DOM tubing
    Body and Glass
    Glassworks 4" bulge 3" rise fiberglass front fenders<br>
    Hannemanns 5" bulge 3" rise fiberglass rear bedsides
    Hannemann 1 of a kind fiberglass hood w/louvers and factory hinges
    20% window tint all the way around
    Interior
    Black cloth seats w/ vinyl floors (nice for cleanup after offroading)
    Manual windows w/ manual locks
    Fuel System
    J*IND custom 46 gallon fuel cell (lined to prevent leaks and rust)
    Uses factory GM fuel pump assembly
    Wheels and Tire
    6- XD series "Bullies" wheels (Matte Black w/ Gold beadlocks)
    6- 37x13.50 17 Toyo Open Country M/T's tires
    There are 2 full size matching spares in the bed
    This truck truly is unique, its fast, its fun, its reliable, and its definitely durable!! Its worth every penny I'm asking for it, especially because I have somewhere nearing the $30k mark spent into it! The truck is located in northern CA by Sacramento, but i am willing to drive it to wherever, for the right price... I'm not very negotiable just cause of the loss in price i am already taking, but if ur interested give me a call or text me anytime @ (209)2two1-5six69 ask for Josh, I'll be more than happy to answer any questions u might have! Please NO low ballers, the trucks worth the price and please only call if your interested in buying!! Thanks
    Here is the link to the CL add with all the details.
    http://sfbay.craigslist.org/eby/cto/3494308876.html
    Last edited by J Industries; 01-22-2013 at 02:14 AM. Reason: To make kerrige happy
    @J_Industries ON INSTGRAM
    TURBO MIC PERFORMANCE
    MAZZULLA OFF-ROAD
    KING SHOCKS
    [HOONIGAN]
