Results 11 to 20 of 24
Thread: can somone please educate me??
  1. #11
    Mar 2012
    west bend, wisconsin
    I found some 243 heads that I'm gonna use with my cam hopefully that will help?
  2. #12
    Arizona/Utah
    If you swap to those heads direct you will lose some compression. You need to swap to 4.8 pistons or mill those heads to make it worth it.
  3. #13
    Mar 2012
    The company that's selling them said they have been milled down to keep the cr the same and ensure a clean mounting surface
  4. #14
    Arizona/Utah
    That should work nicely then. Who are you getting them from and how much do they claim to mill them?
  5. #15
    Mar 2012
    It's a company off eBay with the username synergyss (180) he's got a 100% feedback since 1999 and he said that the deck surfaces are milled slightly. Here's the link http://item.mobileweb.ebay.com/viewitem?itemId=221150463739&index=0&nav=SEARCH&ni d=56469522584 maybe you guys could throw some input in before I bid on them???
  6. #16
    Quote Originally Posted by mattjones View Post
    How much is slightly? A surfacing to make sure they are flat, or .030? Makes a big big difference when it comes to both compression and ptv clearance. You could demolish that motor the first time you turn it over if you don't know.
  7. #17
    Mar 2012
    Ill have to contact the seller about them or maybe I should just find some 243 off an 05 silverado because wouldn't they be ok considering they came off a 5.3 as far as clearances go?
  8. #18
    243's didnt come on the trucks until 07.. And when you toss a set of stock 243's on a stock 05 5.3 your going to lose a bit of compression. If youre looking for something you can just toss on get some 862's of 706's and have them ported.
  9. #19
    L33's came with them in the form of 799's. Exact same head different casting number. They had flat top pistons though. To the OP, I'm running 243's milled .030 with a .598 lift cam. No issues.
    I was under the impression that they were flat tops with 862's still not the 799/243's?
    Guess you learn something new every day.
