Sponsored by Taylor Wires!
Sponsored by PowerMaster!!
Sponsored by FROZEN BOOST!
Sponsored by US Speedo!
disconnect negative battery cable...
close hood and your done...
Hydroboost swap is done... mostly. I still have to bleed the brakes again and cycle the ABS.
A few lessons learned.
1) My brake lines aren't the standard size, they're bigger and metric.
2) My master cylinder wont work with the booster from an 08.
3) The master from the 08 won't work with my brake lines
4) Its always good to carry a fire extinguisher.
Its cus i wasnt there, i can do hydroboost blindfolded![]()
badass conversion ...ill be looking into this soon...just need to find a 08+donor
