Results 11 to 20 of 35
Thread: some notes from a beginner, change rings or change pistons?
Threaded View
    Question some notes from a beginner, 5.3 to 6.0 swap
    as some of you know a blew the 5.3 and bought an LY6 6.0, well, today as i was cleaning the engine and checking the block/ rotating , i found that the pistons have some very low but noticable play when you push them from front to back,
    also the rod bearings look like they have a little ware , should i change that too?
    the last thing is that the first cam bearing have copper colored spots, change or leave?
    here are the pics:
    here is the cam bearing
    bore was smooth with no signs of ware
    the block was in great shape acctulay very slight rust consdering its a 2008 and the junkyard was close to sea!
    so what do you guys think?
