1994 5.7 to 5.3 lm7 swap
Im new here looking for input on swapping a 5.3 with 4l60e into a 1994 silverado 4x4 that currently has a 350 tbi and 4l60e. The tranny is on its way out so I figured I may as well swap on a new one while im at it. Motor mounts... wiring harnesses... these are things ill need help with most. I haven't started the swap since the truck is my DD but im looking for info and approximate cost for a swap. Ive found a 5.3 for 650 with harness and ecm and a tranny for 750. Is this a good deal? Ive also been told that the ls style AC bracket and compressor won't clear my frame... is this correct? Any info greatly appreciated.
- You may not post replies
- You may not edit your posts
