damn why do i have to have lower control arms?!? id order some right now!
What else is needed to do on a 4WD or AWD?
T-RAV99 GMC | 5.3 | Skinny White Guy Tuned
I am VERY impressed with everything done up front on my truck.
I picked up two stock upper control arms and 2" McGaughy Spindles from Mic. Jon replaced the front UCAs and installed the spindles. Everything looks factory up there, and I have these purty blue adjustable coil overs. I can lower the truck more if I wish, firmness, softness, or bring it back up. The geometry is way better than it was, and I wont have to worry about the grease boots bursting and then replacing ball joints. Good deal for anyone!
very tempting..... im about to have to completely go through my front end so this might need to happen
01 Silverado
On the pic with Duckys truck there is probably another inch of adjustment up from his ride height.
The GMT400 uses a different length shock but install is almost the same. Only addition is you need to drill the upper shock hole from 5/8" to 3/4" for the delrin bushing to fit.
The 4wd/AWD is a whole different animal. Only one I've done took a lot of fabrication to make it work properly and also included building tubular lower control arms. No a minor modification at all.
Using stock upper and lower ca's, and stock spindles... - what drop will these have?
99 GMC - RCSB 408 w/98mm whistle...WSLS Racing...
very nice.....if using stock spindle what drop will that achieve?.
2014 Xsport- 3.5 Eco boost
412 Motorsports
what drop will i get with stock spindles?
figured third time is the charm.....![]()
01 Silverado
I haven't put a set on a stock height truck yet. Since Mcgaughtys spindles are 2"drop the ride height could be 2-3" taller than in Davids pic.
Very cool, will be going this route. Thanks Jon for the write up.
Sticky this
