Page 2 of 2 FirstFirst 1 2
Results 11 to 18 of 18
Thread: trans temp
  1. #11
    San Marcos Texas
    Originally posted by jethro_3@Jun 18 2005, 01:06 PM
    Help me figure out why they put the Tach in the auto and no Tach in the manuel trans????
    I think it is because most manual trans truck are stripped.
  2. #12
    Apr 2005
    Saint John, MO
    Originally posted by BlenderWizard@Jun 18 2005, 12:48 PM
    You know, how much extra does it really cost to make the Denali cluster over the standard Sierra/Silverado cluster? I have never understood why car companies equip cars with dummy lights instead of gauges. What's the price difference to the manufacturer, $3 each? I'd gladly have paid an extra $100 for a speedo that went to 120 and a tranny temp gauge instead of a stupid light.
    Well said.
    Base: 2004 Victory Red Silverado 1500 2WD RCLB, LR4, 4L60E, 3.73, HD Suspension, P245/75R16 Tires
    Mechanical/Performance: Nelson 93 Octane Tune (See Slamma's CarDomain.Com Page for more details)
  3. #13
    Apr 2005
    hmm well this escalade gauge is great and all but thats not what i wanted to know lol i was wonderin about drilling a hole in my tranny pan.. plus autometer guages look better anyway oh and i already have the gauge so theres no talkig me out of it
    1999 GMC Sierra black reg cab short bed SLE Z71 5.3 <--CARDOMAIN PICS
    NELSON 93 hot tune, 02 PCM, VOLANT Ram air intake, MSD wires, ACdelco iridium plugs , Edelbrock ceramic shorty headers, jegs off-road y pipe, Dynamax int pipe, 3" Magnaflow Exhaust with turndown, EGR removal, throttle body bypass, vette servo, long servo pin, performance 4th apply piston, B&M shift kit, SLP 160* thermostat, LS1 Fans, NELSON harness, ported and polished throttle body (did it myself, for free lol)..... _______? cam is next as soon as i stop spending all my money
  4. #14
    Jun 2005
    Cumming, GA
    Well, you do what you gotta do, but I&#39;m not sure there&#39;s many people who have done that to a silverado...
    2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
  5. #15
    Apr 2005
    Saint John, MO
    Yeah Dude, your thread got high jacked big time&#33; I helped some, so sorry about that
    You will have to drill a hole in the pan. The pan will have to come off.
    How does the sensor connect to the pan? Is it one of those self threading deals, uses an internal locking nut or screwed it into threads you cut? How far will it protrude into the pan? You gotta make sure to clear the filter.
    For location I&#39;d put it on the back side of the pan, maybe centered 2" up from the bottom. Make sure you are clearing the filter. You need to clear the filter, but still have the sensor in the accumulated fluid.
    For not a whole lot more &#036;&#036;&#036; you could get a decent sheet metal pan w/ a couple of qts more fluid capacity, plus a real drain hole. Both good things. Use that pan for installing sensor, you should be able to get away with another inch, maybe two, of clearance from the pan bottom. Plus, you&#39;d still have your stock pan, just in case for a back out plan.
    Put your sensor wires in a loom (tubing) when running them. That&#39;s a harsh place down there.
    Follow the instructions for the fluid refill to a "T".
    Good luck.
    Mechanical/Performance: Nelson 93 Octane Tune (See Slamma&#39;s CarDomain.Com Page for more details)
  6. #16
    Jun 2005
    Round Rock
    Sorry for the jack , did not know if you thought of the alternative...
    08 HHR SS
    Black on Black 5 spd with no options
    Pics of Christine, the '05 VHO My Car Domain Site
  7. #17
    Jun 2005
    Sorry for continuing the Jack. But I have been thinking about changing the dash panel to a escalade look.
    J3
    My 01 Z71 MPH only goes to 100 is there any recal that has to take place?
    01,Z71 Victory Red, sportside,5.3L, Flowmaster 40&#39;s, K&N Drop In, Airaid MIT Tube, TB bypass, Nelson Performance Hot Tune. Velocity Stack waste of money.
    Working to run with the BIG DOGS, tired of the porch. STS or LQ9 in the future.
    http://i56.photobucket.com/albums/g1...1/DSC02262.jpg
  8. #18
    Apr 2005
    i might go with the new pan that sounds like a good idea it would be easier then i could just get the weld-in adapter and be done with it thanks
