WD40 I believe is just a lubricant. PB actually penetrates the rust and helps dissolve the rust.
2010 Silverado 4.8 Ext Cab 4x4
Cam, Stall, 4.88's
MY TRUCK IS A HYBRID!!! IT BURNS GAS AND RUBBER....
2011 GMC CCSB
Flaco Tune, CAI, Muffler
13.8 @100
340hp 352tq
I skimmed through the 80e conversion but saw some people were having problems with the 4x4 swap. My transfer case selector is a manual version on the floor and I think most of the people that had problems with the electronic selector. Would a 80e with transfer case work with this set up? I know I would most likely have to change driveshaft length.
Cam, Stall, 4.88's
So just an update, I got the headers almost complete on the 2010. The rear driverside bolt is a b*tch to get to. I pulled the inner fenders which does make things much easier. Passenger side was everything you could ever ask for when working on a something, came right apart, header slid in from the bottom. Driver side I had to go through the top and did not need to disconnect steering shaft. I would have had a bit more room if I would have disconnected the front driveshaft but was able to work around it. I needed to cut the original exhaust before the YPipe clamp since the bolt was rusted so I could not complete until I got another piece of pipe. Another tip is to completely remove the transmission crossmember this helps a lot.
Cam, Stall, 4.88's
Good to hear you got them in with out to much issue.. Only problem I see is if you get alot of rain or snow, they are going to be ready for replacing within a 2 year period..![]()
JOHN
An issue I had and it may have just been my set, I had them on for about a year and then swapped motors and when i put them back on they seemed to collapse in and the drivers side started to rub against my 4wd drive shaft but I just pulled the shaft and did a little massaging to the header and it doesnt rub anymore
2006 Chevy ECSB 5.3 - New L33 Motor,CAI, Descreened MAF, Nelson 93 tune, Transgo Shift Kit, servos, 3in exhaust, Borla, pacetter LT's, and ORY, Aeroforce Furture: stall, cam, 4.10's
Another update everything is on and I just need to go through and retighten since I have been through the first heat cycle. My god you feel every exhaust puff there is, I had a series 10 flowmaster on the truck prior to this since and it sounded really good. Now it’s crazy loud so I think I will be shopping for a muffler soon. Not sure about anyone else but I’m still really surprised I cannot turn the tires over from a dead stop. I have a tune (with supposed torque management reduction), intake, header exhaust, factory 265 tires and 3.42 with stock torque converter. I cannot get these damn things to move on a dry road or even trying a brake torque. Any one out there with a newer 4.8 having similar problem?
Here is a link to the Youtube video on stock exhaust/ flowmaster with factory manifolds. http://youtu.be/iTSZqJQ6CqA
Short clip after the longtubes were installed http://youtu.be/wZ_k3PbZ7i8
Cam, Stall, 4.88's
its the 3.42's and stock converter swap to 4.10's and at least a 2800 converter and you'll burn them up
