added a video, yall tell me what yall think about it
1989 RCSS 5.3/4L60E swap
- 224/230 .581.591 112lsa,
- 3200 Stall
- DJM 4/6 drop
- Nelson Tuned
Building the truck GM never did..
Found some 5.3s on Craigslist that I think would work one 6.0 but we will see
- 3200 Stall
- DJM 4/6 drop
- Nelson Tuned
damm ,sounds like the converter..hope it aint major..
just pull the starter and get a socket on each bolt and make sure they are all tight. will only take 30 minutes start to finish
their are some shavings on the dip stick so I'll check everything else before I pull it tho
- 3200 Stall
- DJM 4/6 drop
- Nelson Tuned
dang
That sucks
ok before you go any further. pull your oil filter and cut the end off, remove the filter from inside it and inspect it. if you did spin a bearing youll see plenty of metal in the filter.
2014 Xsport- 3.5 Eco boost
412 Motorsports
It'll look like you struck gold LOL, but its a bad thing
