5.7 coming out of this truck
And this engine (2002 5.3) will be taking it's place
A few parts I have in my room
Oil pressure sensor and coolant temperature sensor adapters
Josh Powers A/C brackets
LS1 E-Fans
Schoenfeld long tube headers with my Tiddies
So far all the parts I have gathered:
AC Delco EP381 Fuel Pump ACF-EP381
Airtex Fuel Pump Strainers ATX-FS22
Airtex Fuel Pump Wiring Harnesses ATX-WH3000
Earl's Performance AN to Metric Adapter Fittings -6 AN to 14mm x 1.5 O-ring EAR-9894DBHERL
Fragola Performance Systems AN to Metric Adapter Fittings -6 AN to 16mm x 1.5 O-ring FRA-491971-BL
Russell Fuel Rail Fitting Adapters Pressure side RUS-640850
Russell Fuel Rail Fitting Adapters Return side RUS-640860
Schoenfeld Headers SCH-1302LS1
(4)Summit Racing® Hose Ends -6AN SUM-220690B
18" -6 AN Stainless Steel Hose SUM-G1001
Trans-Dapt Performance Engine Swap Motor Mounts TRD-4572
LS1 E-Fans
Performance Systems Integration '99 - '03 VORTEC W/ 4L60E STANDALONE WIRING HARNESS (DBC)HAR-1018
Josh Powers A/C Bracket
CrateEngineDepot LS Series Flexplate Kit 12621399
5.3 accessories
Street & Performance oil pressure sensor adapter
Street & Performance coolant temperature sensor adapter
Magnaflow 3" DI 3" SO Y pipe 10798
The things I still need include:
-PCM from Nelson Performance
-E Fan harness from Nelson Performance
-Get my headers ceramic coated
- Air intake
-Just small odds and ends such as a few accessory bolts, and radiator hoses.
-Lastly I'll have a exhaust shop bend me a y pipe.
So far I've spent $2,142.25 and I should have a total of ~$3,000 into the swap when all is said and done.
Planned mods in the future include;
-220/220 112 LSA cam from TSP
-3200 stall from Yank
-fully built transmission
-lastly a 100 shot.
I dream of someday putting a turbo on it but that will be out of my budget for an extremely long time.
Thanks and gig 'em![]()
