Results 11 to 11 of 11
Thread: front mount turbo kit, 243 heads
Threaded View
    Dec 2008
    South Carolina
    Ok so im having to dismember my truck and sell all the go fast goodies as im looking to buy a house...first up for grabs is my turbo kit. Everything minus the turbo is brand new pretty much as it only has around 1k miles on it. This is the whole kit from hot side to cold side to the oil feed and return lines..the hot side is Trick stage 4 ss hot pipes, and had i had a piece fabbed to where the down pipe will bolt up to the factory exhaust... cold side is what i fabbed up using a universal ebay kit..the intercooler is brand new it prob only has been run for maybe an hour after i put it on about a month ago..godspeed 50 mm BOV and a godspeed 38mm wastegate with a 7 psi spring. manual boost controller..all the boost/vac hose.. Turbo is a turbonetics 70mm .81 a/r with around 8k miles on it. Ill even throw in an autometer boost guage, a 2bar gm map sensor, extra 3'' silicone couplers and 3" piping...you will still need tuning, injectors, and prob upgraded fuel pump..$3000 shipped for everything
    Next is a set of 243 heads fully assembled w/ PAC 1218 springs and new valvestem seals. The heads have around 30k miles on them and the springs and seals only have about 5k miles on them. $550 shipped
    I will post up pics tonight or you can text me at 8645426558 and i have some pics on my phone i can send. here is a link to the turbo kit http://www.ls1truck.com/forums/my-ga...merichlsx.html
    2008 GMC Sierra SLE....370ci LY6 with some goodies SOLD
    1995 C2500- LS1 swap with a mp112
    build thread- http://www.ls1truck.com/forums/lsx-t...-ls1-swap.html
