Results 11 to 20 of 29
Thread: Rear mount guys taking opinions and wondering if it will work.408+y2k 88mm
  1. #11
    Arizona/Utah
    Custom ground Cam FTW!
  2. #12
    Mar 2011
    Quote Originally Posted by sprayedenali View Post
    youre spending all this time and money on a awesome motor and turbo,dont skimp on the cam!!! get someone who knows their stuff to spec you one...
    Yea I would like get a custom just dont want to go huge. I have a set of the early L92 heads and I know there thinner but one problem they said was from stress of high lift cams and stiff springs. Also from reading I need find someone who specializes in L92 heads as the common cams ussually hurt the motors performance. Who would you guys recommend to spec a cam?
  3. #13
    Quote Originally Posted by sho_tyme View Post
    Patrick G, no I don't have his contact information. He's like a ghost.
    Arizona/Utah
    Yes Pat G is indeed the man for the job but like David has stated good luck getting ahold of him at the moment. haha
  5. #15
    casey23 Guest
    youre spending all this time and money on a awesome motor and turbo,dont skimp on the cam!!! Get someone who knows their stuff to spec you one...
    like...
  6. #16
    casey23 Guest
    yes pat g is indeed the man for the job but like david has stated good luck getting ahold of him at the moment. Haha
    hummm...... Not that hard to find his info
  7. #17
    Quote Originally Posted by casey23 View Post
    like...
    NOT this guy....he's has no idea what hes doing with turbos or tuning them...
  8. #18
    casey23 Guest
    I know being almost 2sec faster then any truck with a rear mount in a truck is over rated.... only had like 5 turbos on mine... couple of fuel systems... and few then a few "stall changes" lol .... sounds like he already has his mind made up on what he wants
  9. #19
    Mar 2011
    yea I am dead set on rear mount,If you see a swapped colorado you know there is not alot of room. Then throw on top that wanting to keep a/c ps it gets tight in there.
  10. #20
    Aurora, CO
    Listen to casey, i built my rear mount after his and it works great, i daily drive it too on 10lbs. Use stock manifolds (i ported mine quite a bit though) and make sure you keep your y-pipe pipping size down to 2.5" like casey's or your first gear will not be fun lol. Use a dual 2.5" in to a 3" in to the turbo also. I'm running a JGS 400 wastegate with no issues at all. I had my cam for my built 370 speced by patg/eps too although i dont have the motor in the truck yet. Not to sure what casey is running now but i have the exa oil return pump and i bought a back up for long trips lol, its worked pretty well, i tried to buy the weldon return bump but it was back ordered like 4 monthes from weldon. When i started i kept my PS long tube headers and had a 3" into a 3 1/2" y pipe (not recomended by casey lol but im stuborn!) and it didn't work out to well lol.
    07 4WD SCSB, LQ9/LS3 w/LS7 cam, LS3 intake,built 4l80e conversion,custom rear mounted TC78 turbo setup, ported exh. manifolds, devils own meth kit, WTA intercooler, aeromotive f-pump,True Trac, stock 3:42's, "new design" gray 20" american racing torque thrust ST's, 3/4" drop kit, painted grille, hids, welded roll pan, iss wing, Factory ss front bumper, TBSS SW, custom pioneer/infinity system with 10" JL sub
