That kit is pretty damn complete. Even comes with enough wire, if not you might have to pick up a roll of 12 gauge.
2008 GMC Sierra SLE....370ci LY6 with some goodiesSOLD
1995 C2500- LS1 swap with a mp112
build thread- http://www.ls1truck.com/forums/lsx-t...-ls1-swap.html
Those WOT switches aren't junk really. They hold up very well.
Just pull 4* of timing then spray a 100. Add timing as needed. Make sure you change spark plugs to TR6's or something along those lines. Stock plugs are too hot for nitrous.
yea i was wonderin about wat plugs to use...so would ac delco plugs be too hot for a 75 shot? thats the plugs i got in it now
Skip the 50 shot. I hit my truck with the 50 once, then pulled over and put the jets for the 100 in. Stock timing table, TR55 plugs I got no audible knock (hooked up HPT I think I got 1 or 2 degrees of KR). Throw some TR6's in it and I bet you could get away spraying the 100 without even second guessing anything.
videos! would like to see a video of the gauges when you hit it from a roll then hit the spray
1989 RCSS 5.3/4L60E swap
- 224/230 .581.591 112lsa,
- 3200 Stall
- DJM 4/6 drop
- Nelson Tuned
Building the truck GM never did..
