Page 2 of 2 FirstFirst 1 2
Results 11 to 13 of 13
Thread: lifter tap after cam install.......need help
  1. #11
    Pittsburgh, PA
    stock lifters with a upgraded cam will cause noises in older motors. Newer motors dont seem to be bothered as badly as the older ones. It used to be a 50/50 chance that when you installed a cam you either got away scott free or had to pull heads and replace the lifters with LS7 ones
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
  2. #12
    Jan 2011
    Mcalester,okla.
    I have a 6.0 with a 232/236 .612 / 618 113 +2 with dual springs and have no noise but also had heads and valve train setup properly and clearenced
  3. #13
    Feb 2011
    Newport, NC
    well i think i may have found my problem. i went back to the guy that i had tune my truck for me and he done some tinkerin on it and he put it on the dyno just to see what numbers i had, what he found was shocking, 1st pull it made 165 hp and the second it only made 177hp to the rear wheels. both he and i were speechless. After scratchin are heads for a few minutes he asked me if i degreed the cam right and i asked him how do u degree a cam, haha. I told him that i just put it in there with the dots lined up on the cam and crank gear ran it like that. He told me that i might have possible that i got the cam a tooth off. So i called up to Texas Speed yesterday, were i got the cam from, and told him about my problems and he said the same thing my tuner said, that i got the cam a tooth off, so im going to tear it back apart tonight and see if i got it in wrong and go from there.
