What do they mail to you? Just want to get as much information as possible, so I can start to get a To-Do list for my truck.
Run your motor, not your mouth..
04 ECSB 5.3 Sierra: 14.6@95
Pacesetter Headers, Intake, Tune
I bet if you put a took the rear bumper and towing hitch off and put a roll pan, dropped the spare tire, and the tailgate you could pull a 14!![]()
RUN WAT U BRUNG!!!!
Wheatley and Nelson both send you a ECU with a tune specifically for your truck. When you get the ecu in the mail you pull yours and send it back to them. You take the ecu they send you and plug it in and roll! pretty easy.
We did all if that besides the roll pan.. that was before I had the Hypertech and we were trying to lose as much weight as possible so we could get to 90mph.. I couldn't get over 89.96MPH, it was annoying the sh*t out of me. With the hypertech I got to about 91MPH and right now I'm looking int the tune Show&Go was talking about.
Not bad times... considering I ran 14.5 @ 94, except i'm 4wd
04 Silverado Z-71 Extended Cab
Magnaflow, 10.4 TV 50 wires, tr-55ix, Synthetics, HID's, JL audio, 33.5", leveling kit, tuned, CAI, vette servo, cam, valve job, pacesetter. 9.3@77.5 and 14.5@93.4
06 2wd
custom cam, tune, 3.73's, servo, HID's, 10.4mm wires, long-tubes, CAI, magnaflow, 2.5" shackles, Circle-D 3200, UD, JL Audio 4.1, Alpine 5ch
as stated before a tune will help a ton, ive used nelson performance alot and they are always good to work with. you could do a thottle body too for a lil added power i will probably be getting the ebay 78mm throttle body for my truck
2009 silverado z71
Performance: 5.3 p1sc procharger with 3.85 pulley, pacesetter long tube headers, circle d 3200 stall and gibson exhaust
Exterior: debadged, molding removed
Interior: pioneer stereo, jl 10w3 subs, rockford fosgate punch pbr500x1 and polk mm 6.5 speakers in the doors
Suspension: djm 2 inch drop coil and flip kit
dont you already have a 78mm throttle body? or even the new larger unit? why would u get another 78?
06ccsb, cammed, stalled, geared
no i only have the stock throttle body from the 4.8l since im using the truck intake, which the stock tb is 78mm yes but it tunnels down to a 72mm which the ebay one is bored to 78mm strait through.
btw 04SilverBullet since your getting a tune you might get a ls2 intake manifold and delete all your egr stuff as well
2009 silverado z71
Will the manifold just bolt right on? Don't really have the knowledge on what to do to make it fit.
ill be honest i havent looked into it enough yet, but the only problems i can think of would be the injector pig tails not matching up and then figuring out how to block off the egr stuff
2009 silverado z71
