Page 2 of 2 FirstFirst 1 2
Results 11 to 16 of 16
Thread: DIY oil cap breather how-to
  1. #11
    Jan 2005
    Humble/Houston TX
    Catch can will take care of that...
    yeah, it's just about the only option..but oil even gets past a catch can. ive seen dual catch can setups. it is really cluttery at that point.
    old mod list: H/C/I/N/E/G 408
  2. #12
    Mar 2007
    Newark, Delaware
    IF you notice any vapor smell in the cab you can always take the vent to the air filter. That way the smell gets sucked up and recycled.
    I've thought about doing this, but I'm worried it will contaminate the MAF sensor. What do you think?
  3. #13
    San Antonio, TX
    so far so good on the ones we've done. but i bet it would be an issue if blow by was a concern; on a boosted engine.
    of course sd isn't a problem.
  4. #14
    Aug 2009
    venice, florida
    why are there guys that only run breathers on the valve covers and push the same amount boost as guys that run cath can setups and say they dont have any problems? is it just a matter of the amount of blow-by or something else?
    5.3 2wd upgrades: Nelson tune, stainless lt's, magnaflow, e-fans, msd's, cai.
  5. #15
    Quote Originally Posted by Beatdown Z View Post
    That's actually how the NNBS is done. The PCV tube runs up into the intake tube post MAF.
  6. #16
    Plainfield, IL
    Quote Originally Posted by TXsilverado View Post
    the design of the catch can is semi important. The cheap ones on ebay have the inlet/outlet right next to each other, in theory oil can 'jump' from one to the other. Taller catch cans tend to hold oil better, and the higher end ones actually have internal walls/baffles (for lack of a better term) to stop the oil. The cheap ones are just hollow cans.
    For smell/moisture catch cans really are the best way to go, but good ones can be rather expensive.
