I am wondering what rpm you guys are at. Post you tire size and rearend ratio. If possible post what 4l80e you have. I heard that the 80e behind the NPR had lower gears than the 80e in silverados.
2007 GMT900 CCSB 5.3 VTS2300 Twin Screw Supercharger, Doug Thorley LT's, True 3" Duals into Dynomax Race Bullets, Nelson Tune, 4L80e w/transgo HD2-D, Truetrac, 4.10 r&p
Need list: Stall, PLX 200 for my crappy AFR, X-pipe, GM 20's.
im running a 4l80e with a 4k stall and 4:56, runs great
i have 4.56 was going 80e but now 6spd well see how it does..all i know 4.56 were badass on the 60e i ran
I'm running the 80e with 4k stall and 4.10s. 1.68-1.75. Has cut 1.52 on bottle. Truck doesn't 60ft like I want. 29in tall tire I cruise 70 at 2200 rpms though.
Slowest in Oklahoma...
so u get an idea i was at 3,000 rpm at 75mph...3200 stall/4.56 gears//4l60e 28' tall tire
80e with 3.42's and 28" tall DR is 2000 at 70
'13 silverado LT...stock
'11 lt 4x4 z71..tvs1900
80e , 3.73, 30.45" tire, 19xxrpm at 70, 146mph@6000 rpm at 3rd gear top speed
Just ordered a set of 4.11, will report as soon as I install them !
