Results 11 to 19 of 19
Thread: 92 Silverado 5.3/60e conversion
Threaded View
    May 2010
    so cal.
    So this truck started out as a 4x4 K1500 with a 5.7tbi and a 700r4 trans. It is now in the process of being converted to a 2x4 1500 with a mildly built 5.3 and mildly built 4l60e. These were both pullouts at a junkyard out of an 04 Avalanche. The reason for the 2x4 conversion is the cost of an adapter to use my 241c tcase with a newer model 60e. And the pullout of the Avalanche was a 2x4 so I would have had to also convert the trans to 4x4. It just started adding up quick and I'm on a budget...sort of.
    So the mods to this 5.3/60e are this:
    2004 5.3 lm7 with 80,000 miles
    TR220/220 112 lsa
    Comp 918's/hardened pusrods
    Vette Filter/EP381 pump
    Schoenfeld lt's
    ls6 intake
    Custom HPtuners tune by a friend of mine
    Custom cold air intake
    Ls1 electric fans
    Transgo HD2
    Circle-D 3000 stall
    B&M cooler and deep pan
    Autometer Gauges
    Well I started taking pics kind of late so I apologize to you guys for that. Started out by tearing the engine down to a short block to check it out and install the cam and springs. It looked great still showing the hash marks in all 8 cylinders.
    Next we installed it in the truck as a long block so that I had room to mount radiator/fans
    Here's a few teasers:
    I will do my best to update this with as many pics as possible. Next is the accesories and then the wiring harness.
    SOLD:1992 ECSB Silverado lm7 5.3 Swap, TR220 cam, Circle D 3200stall, CBM street tune, Schoenfeld LT's, LS1 efans, transgo hd-2 60e, custom CAI, Autometer gauges
    Best 1/8 E.T. 8.86 @ 77.8 on 275/60/15 MT ET Streets with 1.92 60 ft.
    2000 RCSB 4x4 Lq9 swap...stock except mild 4l65e....for now
