thats what ill do,hit up the local welding shop and get some wire there.i just got the optima hold down kit.thanks guys,guess no one has done this yet on a NNBS"?
Get the welding wire, it's made to withstand more abrasion, like said above.
Also, be sure to ground every point on your truck, chassis to battery, chassis to block, block to battery, block to.....
The welding company may have the correct 0/1g terminals as well, I know autozone or any other auto shop doesn't have sh!t.
www.waytekwire.com has some decent stuff as well.
Nelson Performance
FastestTruckList.com
NP on Facebook
Youtube Channel
i personally wouldnt use welding cable, or if you do, make sure you use a good woven loom around it.. it takes forever to pull it thru, but its much better than plastic loom.. i work at an alternator/starter shop and too many times i have seen someone use welding cable, and it rubs in two somewhere and shorts a lot of sh!t out.. it also is not very oil/gas resistant as it eats the coating off.. also, never EVER buy battery cables from any parts house, unless it is going on your lawn mower, their 4 ga cable has the same amount of copper as a good 8 ga cable has.. and NEVER use bolt on cable ends, always use either crimp on or solder on.. just a lil advice from a 12Volt guy..
Truck: 05 GMC CCSB SLT Z71,
Go Faster: 5.3, 219/227 .607/.614 112, milled heads, eBay CAI, Circle D 2800, 3030 Built 60E, E-Fans, 3030 Tuned, LT's, Spintech Muffler, DuraGrip w/ 3.73's
Look Better: 10K HID's lows & fogs, tinted Chevy tails
I have to disagree. Have you seen the stress that welding cable goes through on a daily basis? I work pipeline and have watched welders drag leads for miles when someone forgets to roll one up. Pipeline welders get their leads covered in gas, oil, dirt, mud, deisel, glycol... Welding calbe is just fine. It has been used for batteries, stereos, and much more strenuous work for years.
As to it rubbing... well, if you give any wire an opportunity to rub, it will.
i aint gonna argue with you about what it goes thru.. im just stating what i know from what i see daily.. welding cable will work fine, as long as it is clean and has a good loom around it.. do i prefer to use it, no.. but the insulation on welding cable is more prone to deteriorating faster than that of a good quality battery cable...
haha there was a huge thread on using welding cable etc. its somewhere in here.
I haven't used welding cable on automobiles, but I have bought replacement welding wire, it's thick, resistant to rubbing and holds up well.
But I would agree to put some loom around the bends and secure it correctly with fasteners.
For all smaller wiring, we use only TXL rated wire, that stuff will hold up very well. Sometimes it's not available in larger sizes though.
Here's something cool, last time I placed an order with the wiring company, they sent me a 100ft spool of 0g HD battery cable in place of a 500ft 18g spool, damn, what a good deal! (the 18g spool is only $40/roll)
Nelson Performance
NP on Facebook
Youtube Channel
Not only ground everything but run a ground wire from thebattery back to the front. I know I know frames have been used to transfer grounds for years. But electronics are more sensitive to voltage drops.
Online Store
[/CENTER]
i say just use welding cable, and i saw this some time back. this guy is using flex conduit to run the power cables, under his car.
http://forum.realmofexcursion.com/ac...-your-car.html
im going to get the cable today ,ill get some pics up soon.thanks for the info guys!
