Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
Thread: belt squeel .
  1. #11
    Jun 2007
    I've replaced the tensioner ,and idler. I've used several belts including a shorter one. I was thinking of grabbing one of those gator belts and trying it. I did just check my powersteering fluid and found it to low , so I started it in the garage and it didn't squeek but sometimes it doesn't do it till I go down the rd. I'll let u know if that does it
  2. #12
    Jun 2007
    My bad lol. I forgot when I was changing things around I used a 105amp alternator,moral of the story an even shorter belt worked .wen I used what I thought was a smaller belt wasn't so I happen to realize hey I used a smaller alternator let's see if theyres a difference , yes red I know lol.right again . Thanks for all the help guys
