Page 2 of 2 FirstFirst 1 2
Results 11 to 14 of 14
Thread: 08 ls2 into an 02 1500. What's involved?
    Nov 2009
    Fort Smith, Arkansas
    Quote Originally Posted by La Ricky Bobby View Post
    wut has 2 be changed if im putting an 05 lq4 into my 1994 GMC ecsb? just the major i know reluctor,crossmember moved back, motor mounts driveshaft, efans,yoke, and a nelson harness, wut am i missing? sorry 2 interupt ur thread SS..but wut he said is wut has 2 be done..go with his advice
    You dont have to swap a reluctor wheel as long as you have a matching computer. You dont need to change the motor mounts just get motor mount adapter plates. And depending on which trans you plan to use you might need to change flexplates. Also depending on which trans you use you might not need to have a different driveshaft. Youll need gauge sending unit adapters to make your gauges work.
    '91 2WD RCSB
    5.3l L59 DBW
    4L80E
    TR220 cam
    RevMax 2800rpm stall converter
    Schoenfeld LT Headers
    Nelson tuned
    My Truck Video - http://www.youtube.com/watch?v=Rw9y1...&feature=email
    May 2010
    Quote Originally Posted by flattopwill View Post
    Im using the matching 05 4L80e.and i have the complete wiring harness and ecu...where i do look 4 the gauge sending unit adapters?
    Nov 2009
    S&P catalog pg 94
    '91 2WD RCSB
    5.3l L59 DBW
    4L80E
    TR220 cam
    Nelson tuned
    Gramercy
    to OP
    i swapped a 08 5.3 into a 94 chevy. just scroll through the thread and you'll see EVERYTHING you have to do to make it work.
    if he is getting the LS2 torn apart just change the reluctor wheel while its apart. just look at my thread you'll see all the info you'll need on a Gen IV block in a Gen III truck set up.
    good luck.
    2008 GMC CCSB 6.2/6L80e swap
