nm.. see stock tranny.. thus stock stall?
04 Silverado Z-71 Extended Cab
Magnaflow, 10.4 TV 50 wires, tr-55ix, Synthetics, HID's, JL audio, 33.5", leveling kit, tuned, CAI, vette servo, cam, valve job, pacesetter. 9.3@77.5 and 14.5@93.4
06 2wd
custom cam, tune, 3.73's, servo, HID's, 10.4mm wires, long-tubes, CAI, magnaflow, 2.5" shackles, Circle-D 3200, UD, JL Audio 4.1, Alpine 5ch
yea...the build sheet says it's a 3:42. I haven't done anything to the tranny!
hey casey your guys like the 4.56s? thats what im wanting to put in my swb 2wd escky. im on 22'' and my tires 305-45 about 31 1/2 overall. ill be moving down from a 3.73. mostly curious about interstate driving and mileage increase/decrease after combineing the gears after the bigger wheels/tires. hopefully this not hijacking
5.3 2wd upgrades: Nelson tune, stainless lt's, magnaflow, e-fans, msd's, cai.
2100/2200 my truck is such a turd off the line id give up lower cruising rpm's for a little take-off.
fyi...this is the cam i went with!
Comp Cams 212/218 LSx Cam "HIGH LIFT"
a) get a hi stall torque converter...
b) the yukons/suburbans/some 1500HDs had 4.10s stock, but you're still going to have just a g80. Ron's gearshop can get you a true-trac and a set of gears for 600 to your door. Then you just need to have them installed. Most rears out of a boneyard are atleast 500 now a days for these trucks, so you're probably better off rebuilding yours.
If not search for the RPO codes. I used to have them memorized, but can't remember now. The stick is in the glovebox. Tells gear.
ronsmachiningservice.com Awesome guy and extremely helpful!!
So what did you end up going with? I have a 06 5.3 CC Silverado with 22's. Its a turd off the line and i want to jump to 4.10 or 4.30.
