so it sounds like those MT 28 x 11.5 x16 tires will work fine on stock GM NBS 16in wheels? but aren't those only like 8in wide?
and what about running big tires up front and small out back?(32" vs 28")
2003 GMC K1500 ECSB running an Iron 383 Stroker ......
im getting some hoosier 28x10x16 full slicks. They are actually wider then the mt streets and being a full slick should hook better
im about to go to a set of 390/40/15 on a 15x12" rim so i can hook at the track without being too far off from my tire diameter
2008 GMC CCSB 6.2/6L80e swap
so what would one have to do to run 15in wheels in the rear? I have discs. little grinding? pics?
thanks
The stock tahoe wheels I have are only like 6.5" wide, maybe 7" so the tire is a little bubbly looking but I had no trouble when mounting and balancing them, they deffinatly need a wider rim! But I pick up both rims for $10 and I couldn't pass it up! They work for me! The first time at the track with them I was running 20psi because I had to drive home on them, and I was spinning pretty hard! So tomorrow I'm hitting the track again but my buddy is going an I'll just throw them on there instead of driving out there on them! I'll be playing with the psi anywhere from 10- 12 psi! If I hook I
Sure I'll be in the 13's my 60' spinning was a 2.1 to a 2.3 so if I hook I hope to break the 2.0 barrier! And iF so I'll be happy! I really want a 13 NA cuz at the end of the month I'll have a 150 ready!
chevyboy.520
06 ecsb 5.3, FAST LsxRT 102, FTI cam! LT's, tru dual, magnaflow, 3400 stall, Performabuilt lvl2, 4.10s!
PRC stg 2.5 5.3 heads Awaiting to go on!
