Selling my 2001 silverado extended cab 1500 truck. This truck has alot of performance mod/parts on it. The motor has a Lunati Voodoo cam 212/218 duration, .531/.531 lift on a 113 lobe seperation. It has a high pressure oil pump, Z06 valve springs, LPP long tube headers with off road y-pipe into dual magnaflow mufflers dumped over the axle. It has a newer design HD radaitor and electric fans, K&N cold air intake, 160* thermostat, the brakes have been converted to hydobooster power brakes. It has a aux tranny cooler, the transmission has been rebuilt about 12k miles ago with all the best clutch, sprags, beast shell, transgo shift kit, servo's and GM 5 pinion planetary making the trans very strong and solid shifts. Installed it a 2800 stall converter. The rear end is built with 4:11 gears and a new TruTrac from detroit lockers. Tires are 275/60/17 on painted black factory wheels. The interior is perfect, no stains on carpet or broken trim. It comes with an Apline CD/Ipod radio, Diamond Audio mid,highs, and 2x10" powered by one Sound Stream amp. It has a GMC Denali cluster install. Ac,brakes and complete vehicle in ready condition. The motor has been tunes by Nelson Performace! Look at photobucket under jermoslin albumn 01
Please ask any question. $7500.00
