62...they are completely stock, only run on the car(Z06) for a few thousand miles.
stock 243's are 64.45 cc ....
I actually put that first, and then went and changed it. But they would be outside of your CC range unless you wanted to get them milled before installing.
ya, I don't want to pay 700 before any machining. I can get a set machined/built for about 1000
But will the ones that you get that are machined and built have the patriot dual springs with max lift of .660? if that's to high make an offer.
The price on the heads isn't terrible...it's just not what I need. Those will lower my compression to around a 9:1, so I will need to have them milled down, clearances checked, etc.
Brand new 59cc 5.3 heads are only 1200. I can have my stock heads worked for around the 700 (includes buying springs).
Okie dokie...good luck
