2000 Sierra rcss, LS6, xr265hr-15, HP Tuner, B&M, traction, cai, 2-4, 3.73 G80, Centerline, Pacesetters w/custom pipes and mufflers
 Senior Member
						Senior Member
						Addco stuff is good too and $100 cheaper for the pair.
01 ecsb 5.3 4x4 z71
Avalanche 17s and a pant load of miles
61 Corvette
350, 4 speed, 4.56's
32 Ford 4 door sedan
keeping it "stockish"
So now my question is....What size front sway bar do I have? 04 Silverado with HD suspension. I was told by the dealer it was the larger of the two listed. What are the available sizes?
2010 Silverado ECSB LS 4x4. Only mods so far are a K&N drop in filter and a Rough Country 2" front level kit
Nevermind 1 7/16
i would check them out on andys auto sport, i have been looking at them
That is the cheapest place I've found online for the Hellwig. Hope my cracked stock can last a few more weeks until I can get the money for a new one.
 of the few lifted ones
						ill sell you the stocker off my truck. i took it off, to much trouble with my lift. its the larger one as well. send me a pm if you want it
Today 03:25 am 6 stringer o thats a good point, its ok ill just add a blinker fluid cooler
Today 03:24 AMtruckinL33 that's not a good place for it, you can overheat your blinker fluid with the capacitor
Today 03:23 AMtruckinL33 i need them for when i go back to 1985
Today 03:23 AM6stringer i mounted my flux capacitor next to my blinker fluid resevoir
Today 03:22 AMtruckinL33 me too, right next to my flux compasator!
Today 03:22 AM6stringer hey gear oil needs to be cooled, i have front and rear diff coolers
you can always weld it if you are worried, they are just 4140 heat treated steel which weld really well with a mild steel wire in a mig welder or a 7018 stick rod, just be sure you don't cool it down really fast after you weld it, otherwise it gets brittle
and will break some more
www.tjc.edu
6stringer PM sent
