Page 2 of 2 FirstFirst 1 2
Results 11 to 18 of 18
Thread: Wifey's tahoe is sick
  1. #11
    Quartz Hill, CA
    My wife's Tahoe did the same thing. I swapped out the MAF and plugs and it fixed the problem.
  2. #12
    Plainfield, IL
    unplug the maf...should go to 'get home mode' should run without misses...if not plugs/wires... NO WAY cats are going out already
  3. #13
    It's the tune!!
  4. #14
    Apr 2005
    Quote Originally Posted by PurpleMinivan View Post
    It's the tune!!
    That was my first choice
    Gone, but not forgotten!
  5. #15
    Jun 2007
    my cats went at 86k .but i will say the process of elimination was to change or clean MAF first according to mitchell.with the same codes.I was even a nice guy and changed ,plugs wires, injectors,fpr,fuel filter,fuel pump cus i had slightly low pressure.In my opinion it had no reasons that even acted like cats,except loss of power.my 2cents.so i hope u have better luck and cheaper than me.
  6. #16
    Quote Originally Posted by oleshifty View Post
    Why do you say this?
  7. #17
    Intake gaskets perhaps? Reason being a couple trucks have rolled through at work same problems and both of them needed gaskets. Something that takes 30 seconds to check it's worth a shot.
    Feb 2010
    Central Texas
    I agree with all these good ideals. Clean your MAF, then I would ck fuel pressure at idle and under load driving down the road to see if it drops off. tune-up if you still don't find problems, but its hard to believe converters would be stoped up at this point
    BB
