Page 2 of 5 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 41
Thread: problems with 4l80e swap..:(
  1. #11
    thanks for the help guys
    2003 silverado x-cab stepside fully loaded..nelson tune..green CAI..160 thermostat..ls6 intake..pacesetter LT's..3"magnflow hi-flow's..one chamber flow dumped..4L60E PATC 1-2 servo 4th servo..trans go HD-2..ridn 24's...2" 4" drop..detroit tru trac an 4.10's setin n the shop waiting
  2. #12
    Quote Originally Posted by wstewart58 View Post
    it just felt like it was taking off in second to me but when i went from a dead stop i could count the gears and then it would lock up in 4th at prolly 60 to 70 mph..guess its time to put the cam in now it actually feels like it's slowed me down lol
    Yes, adding an 80e to a mildly modded 5.3L will take away some power. Since you have a big stall, add a larger cam and have some fun!
  3. #13
    it was an 80e Ls converter i used the 5.3 flexplate...converter was seated in as far as it would slide into the trans...i was told you didnt need the spacer if using the 5.3 stock flexplate
  4. #14
    When you seated the converter, did it fall down all the way into the keyway slots? How deep did it sit inside the bellhousing?
  5. #15
    it locked in the slots as far as it would push in..it didnt butt al the way up to the trans there was prolly a 1/4 or a tad more still exposed between the trans and converter i found that odd but i ignored it with what i had been told
  6. #16
    Yup, you did it correctly.
  7. #17
    omg you had me wryd there for a second lol...so you do not need the spacer when using the stock flexplate
  8. #18
    Augusta, Ks
    He used an older 80e too btw dont know if he mentiond that.
    2004 Buell XB12s
  9. #19
    Quote Originally Posted by WARLOCK View Post
    Hmmm...yeah, it depends on what year.
    But hey--if everything bolted up fine, I guess it worked.
    (Thinking to myself) I didn't think the stock 5.3L flexplate had the proper holes (6) for the 80e converter to bolt up to it...
  10. #20
    Augusta, Ks
    Good call tyler.
    2004 Buell XB12s
