Results 11 to 14 of 14
Thread: m90 magnacharger side mount up for grabs!!
Threaded View
    Aurora, CO
    Talking m90 magnacharger side mount up for grabs!!
    !!!!!!SOLD!!!!!!!!!
    I will be removing my m90 magie side mount here in about a week. Supercharger is in great shape with no issues, comes as complete kit! Comes with all supercharger parts, 99-01 water pump (needed for install on all models), inlet pipe for intake manifold with gm air temp sensor, 5-6 psi belt and pulley setup, 8-9psi belt and pulley setup, both belts and water pump have less than 6k on them. super charger unit only has 6k and is a new unit directly form magnacharger! All the pipping has been hand polished. Has a wicked wine to it! This will fit 99-07classic gm full size truck with 4.8,5.3. Mods you should have are, 225lph pump, injectors (have to be stock length!!), NGK tr7 or tr6 plugs, custom tune with EGR delete. Only fab needed to install is: lengthen heater hoses, grind off one unused threaded bung from rh valve cover, cut and extend air temp wires from maf to temp sensor near intake manifold inlet and change to 99-01 style water pump (included!) for the newer DBW trucks. Asking $1500.00 or $1800.00 installed if your near me? I have $2000.00 in it with all the new parts! Any questions feel free to ask!! here are some pics and a video too!
    Pictures by chargedlq4 - Photobucket
    07 4WD SCSB, LQ9/LS3 w/LS7 cam, LS3 intake,built 4l80e conversion,custom rear mounted TC78 turbo setup, ported exh. manifolds, devils own meth kit, WTA intercooler, aeromotive f-pump,True Trac, stock 3:42's, "new design" gray 20" american racing torque thrust ST's, 3/4" drop kit, painted grille, hids, welded roll pan, iss wing, Factory ss front bumper, TBSS SW, custom pioneer/infinity system with 10" JL sub
