Results 11 to 20 of 26
Thread: How high can you spin stock rods...
    Quote Originally Posted by Slimsilverado View Post
    I know of one guy here local spinning his LS2 to 7200 daily, and he does have the ARP rod bolts. Mine spins to 6500...
    Local guy has stock rod bolts, not ARP's... the truck intake was the killer past 6500 rpms. A fast 92 or pro flo will fix the fall off.
    newburgh, NY
    I spin my stock ass 5.3 with 223k on the clock to 6100. As soon as I swap cams it will jump to 6300. As far as I knew quik was going up to in the 7500 range on his stock bottom end 4.8 with the PT88.
    I believe he has rod bolts and upgrade valve train components not sure what.
    Step 1. crus at it.
    Step 2. get a hammer.
    Step 3. torch it.
    Quote Originally Posted by trx2stroke4life39 View Post
    Well yeah he's got upgraded valvetrain. I couldn't remember if he had rod bolts or not though.
    6900 myself!!! then again thats were i shift at ooops then again i'm not on stock rods lol
    Simple: 408 on steroids!
    single digits coming soon!
    8000 here
    casey23 Guest
    built motor...built trans ... i spin it 6100
    Jan 2005
    Humble/Houston TX
    i spin 6900 and have slammed the limiter at 7200 rpm more than i can count.
    stock bottom end 135,000 mile old LS1.
    old mod list: H/C/I/N/E/G 408
    Pittsburgh, PA
    7700 is highest ive seen. i have dual springs, double roller timing chain and ARP 2000 rod bolts. thats also with 16 psi thru motor at that rpm
    motor still pulls clean at 7500
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    i have spun mine to 6900 but that was an accident usually its about 6500.
    Racoon Twp., PA
    2013 CC 5.3
    81 C10 LS1 project
