04 Malibu
04 Malibu
'86 Silvy- '06 6.0/4L80E, K&N, 2.5 X-pipe Magnaflows, 20" Foose Wheels, Auburn Pro, 3.90 Richmond Gears, and the list is growing!!!
I think you'll need the seat heater modules, and the switches, to make it work like oe.
there is are 2 4 wire plugs and a 2 wire plug on each mod
1st 4 pin plug(Grey connector)
pin 1=Black=Ground
pin 2=lt Blue/Black=Drivers switch
pin 3=Yellow=Acc Voltage
pin 4=Red/White=battery+
2 pin plug
pin 1=black=ds seatback element ctrl
pin 2=black=ds seatback supply voltage
2nd 4 pin plug (Green connector)
pin 1=red=Seat cushion element supply voltage
pin 2=grey=ds seat cushion temp senson low ref
pin 3=grey=seat cusion temp senson signal
pin 4=black=seat sushion element ctrl
passenger side is the same, except plug 1 pin 2 is dark blue/black
then theres the switches
pin 5=yellow=acc voltage
pin 6=black=ground
pin 7=light blue/black=switch signal
pin 8=instrument panel lights
I think this should do it, and the modules should already be attached to the bottom of the seat and with any luck still wired to the seat heater so you'll only need to do 4 wires on each seat
stay warm
01 ecsb 5.3 4x4 z71
Avalanche 17s and a pant load of miles
61 Corvette
350, 4 speed, 4.56's
32 Ford 4 door sedan
keeping it "stockish"
