TCC and overdrive are two things. Overdrive spins the output shaft faster than the engine. Overdrive is obvious internal to the 60 and 80 but the Gear Vendors is a planetary 2-speed gear box that mounts to the rear of the transmission kinda like a single output transfer case. Since it has two speeds you can split each gear turning a 3-speed trans into a 6-speed (although the ratios would be so close you won't normally split all three during a race). 1st low, 1st high, 2nd low, 2nd high, 3rd low, 3rd high. The TCC is merely a clutch inside the converter that locks up to stop converter slippage.
That's why they say 4th is 0.7:1 in a 60E...less than 1:1 (3rd gear). The new 6-speed autos don't have a direct (1:1) gear.
what about the speed sensor output and the pn safety switch how would i wire those up
2005 Chevrolet Silverado 2500HD CCSB Duramax Diesel MBRP 5" down pipe back exhaust EFI live dsp5 via Duramaxtuner 60gal rds in bed aux fuel tank
1997 Chevrolet k1500 ex cab z71 solid axle swap 18" lift 44" truxus sts' 6.0 Texas speed 224R 224/224 .581"/.581" cam/th400/np205
There is an adapter for the VSS, ask DamnYankee or mean05. There is no PRNDL switch needed...only a P/N switch for safety (mounted to an aftermarket floor shifter) unless you want the stock gear display in the info center to work.
ok what you think of this setup
6.0 comp 222/224 cam th400 np205
3200 stahl transgo 400-pro shift kit and a deep pan ????
Is the th400 and 4L80 the same t-case adapter? If not it could be more expensive for an adapter if you use the 205 on the 4L80. My 4L60 to np205 adapter was over 400 bucks from Advanced Adapters. A stock 400 to 205 would be much cheaper. That sounds like a sweet setup to me man. What year trucks this goin into?
