So your saying that you had a better 1/8 mile with a stock cam? I can vouch for aggressive cams having no gains on the bottom end. My cam in my 4.8 didnt even hit power until 4k rpms. But dyno side by sides show that before 4k rpms, graph was identical. After that it got a 60+whp gain all the way to 6500. Another thing is I said ''
usually'' in bold letters. Because people think that they are going to see 50whp below 3k rpms, with just a cam.
If you put a 3600 stall on anything, you will see better times. Doesnt mean that you gained any power, or lost any. It means the stall is keeping the engine in the wanted rpm range at WOT. The reason they dont start the dyno until after 3krpms is because any power down there is moot. Show me a dyno of a 4.8 or 5.3 n/a that makes 300whp below 3000rpms. And if you find one, copy his setup. That way when you put your foot in the gas you get nothing because your only at that rpm in 1st gear.
Oh and not all high duration cams are for hi rpms... a lot of them make power alll over the rpm range.
-1 PH
