Results 11 to 20 of 22
Thread: Need help removing torque converter allen bolt
  1. #11
    Round Rock, TX
    Anytime I ever roll a motor over and see the allen style I immediatly go grab the air hammer, its not even worth the trouble to try with a allen. I broke that rule a few months back on Duckys and we rounded one off, LOL, so I retaught myself that lesson again...haha The air hammer takes less than 2 seconds to break one loose, then use the allen to take it out.
  2. #12
    Yeah, Jon has the best solution in this case. I do not chisel them out as a rule but it will work. I use an Allen socket 3/8" drive on an impact. Do you know anyone with an air hammer?
  3. #13
    Augusta, Ks
    I used an allen socket and an impact to get mine out as well.
    2004 Buell XB12s
  4. #14
    You can do anything with an air hammer
    San Marcos Texas
    Weld the wrench to the bolt!
  6. #16
    Good idea, but welding it would only allow you to turn it about 1/4 turn...then your screwed.
    Mine had the allen heads too, but mine came out fairly easy, I had an allen wrench that was about 1ft long on the handle.
    http://i121.photobucket.com/albums/o...IMG_2118-1.jpg
    1999 Silverado 1500 Z71/5.3 to LQ4 6.0 swap/ CAI/ crappy exhaust/ tuned by COWL327
  7. #17
    Jun 2009
    Dublin, Ga.
    Quote Originally Posted by TDK08 View Post
    not if you cut the end off and use a socket .
    '00 Silverado, '98 Trans Am, and a couple other toys.
  8. #18
    Round Rock, TX
    Just weld the inside of a gearwrench on it....
  9. #19
    OK, still have got the last one out yet. It's been raining alot here. I have another question...What year trucks can I get a transmission from? The junkyard said only 2001s. What could is different? Mine is a 2001 4.8 regular cab 2wd.
  10. #20
    Jun 2009
    Dublin, Ga.
    physically, nothing is different. electrically, maybe a different plug or something, not sure on this, but should all be the same. i am running a camaro tranny in my truck and the only difference is the shaft coming out for the shifter is shorter and i had to rig the shift controller to work for my truck to be able to crank.
