Page 2 of 2 FirstFirst 1 2
Results 11 to 17 of 17
Thread: timing question please help
  1. #11
    Jun 2009
    Timing
    got the knock sensor fix but ut still runs bad i inplug the timing wire then it runs pretty good what can b the problem thanks in advance
  2. #12
    What in holy matrimony are you working on?
  3. #13
    Jun 2009
    93 chevy 2x4 with vortec 5.7 with edelbrock multi point fuel injection
  4. #14
    I have no knowledge of the E-brock FI. What type of distributor does it use?
  5. #15
    Jun 2009
    it uses the stock distributor and all the stock sensors if i leave the wire to time it with unplugged it runs pretty good just a little rought idle thans for the help
  6. #16
    Off a tooth, balancer ring spun, or maget cracked on shaft.
  7. #17
    Jun 2009
    i will check that thanks for the info
