Results 11 to 20 of 24
Thread: Header Wrap
  1. #11
    S.A. Texas
    Wrap them cause it looks cool too. I had my pacesetter LT's wrapped.
  2. #12
    Spring, TX
    Quote Originally Posted by sleeper1500 View Post
    The only thing I can think of that would make wrapped headers rot out faster is that it doesn't allow the metal to breathe, everything just festers underneath. If that makes sense I'm kinda reaching now.
    ^^^^I heard that also. i even heard that some companies void the warranty if you wrap them because of this.
    Edit: i shouldve quoted to begin with
    '02 Silvy: Z71 EC Step Side 5.3L Nelson tuned
    2013 GMC Acadia: SLT1 Carbon Black
    1976 Corvette Stingray: Trying to save it, progress is slow.
    ^Ricky's Sweet PS Skilz
    09/21/2010 02:31 <danger_ranger83> I'm not really worried about the looks...I want it to be fast and ugly...bc no one wants to get outrun by something ugly
  3. #13
    Southern WI
    It will void the warranty, but I wrapped mine I used a 2" 50 ft roll on each one and that was just about right, had a few feet left over. I like it because it not only looks better IMO, but you can run the crap out of your truck and pop the hood and still put your fingers on the header immediatly after. I do NOT recommend doing this and want no responsibility for it, just saying I have done it haha.
    Mike
    2000 RCSB
    '05 LS2 11.5:1 C.R. l K&N l LT's l Torquer V2 l PAC Springs l Manley 7.4's l 92mm TB l LS7 Lifters l Circle-D 3200 l P&P TB l ARP Rod Bolts l LS1 E-fans l Nelson 93 Tune l Brand-X 100 Shot l Walbro 255 l Duals w/ X and Magnapacks l Vette Servo l Transgo S.K. l 30K Cooler l Detroit Tru-Trac l Motive 4.30's l ARP Cap Studs l TA Girdle
  4. #14
    Stainless cools fast. I can touch a pipe on a new truck just a minute or so after it is shut off.
    Then again, I turn bacon bare fingered.
  5. #15
    Stillwater, Ok
    send them off to HPC (High Performance Coatings) or Jethot. They will coat them inside and out....cool to the touch faster, and won't rust.
    2003 SLT Yukon, KMC SS 20's, Nitto 420, Flowmaster exhaust, Eibach 2/3 drop, HID's, AEM CAI , Custom Flames from Godspeed Customs, Corvette servo
  6. #16
    Pittsburgh, PA
    Quote Originally Posted by blueflamed03 View Post
    coatings still get knicked up and start to rust. i havent seen one set of mild steel headers not rust.
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
  7. #17
    Stillwater, Ok
    a bunch of local guys have used HPC coated ones for years, never had issues...but we're further south.
  8. #18
    Jan 2006
    I would wrap them, but use the silicone high heat spray first on the header, then wrap the header, then spray the high heat silicone spray over the wrap lightly. They will be water proof and sealed. DEI makes the spray.
    Jamest
    12 Sec. Club! SOLD
    SOLD***
  9. #19
    Steel headers coated inside and out won't rust through here in decades. Depends on the environment.
  10. #20
    DO NOT coat them on the inside. You will end up with O2 issues. Trust me. Didn't happen to me, but it was the culprit for another member who spent hundreds of dollars and hours of time trying to figure things out...
    I would definitely check with Pacesetter about their warranty--and if it mentions wrap voiding it...
