Page 2 of 2 FirstFirst 1 2
Results 11 to 17 of 17
Thread: No 4wd
  1. #11
    I am an idiot. I thought you said in the diff. Sorry.
  2. #12
    Haha it's OK man.
  3. #13
    Feb 2008
    Arizona
    I had that exact same problem in my truck, I replaced the decoder engine or actuator in the t/c, not sure on how they call it but that fixed my problem..
    06' Silverado RCSB 5.3L 4wd..
    HID's Hi, Lows & Fogs
  4. #14
    The encoder motor moves the shift fork. If it were messed up you'd get codes and a message.
  5. #15
    Jun 2009
    Eastern Kentucky
    no 4wd
    i have no 4wd the lights ain't on an it says to service 4wd? it is on a 04 chevy silverado 1500 z71
  6. #16
    Quote Originally Posted by chevymanx2 View Post
    New problem
    Make sure the switch is plugged in.
    Make sure the fuses in all three locations are good. Make sure the module is plugged in and you do not have a windshield leak getting the module wet.
    Beyond that you need scanned for codes.
    You also need to make an introduction topic in the newbie section.
  7. #17
    Augusta, Ks
    Darn s
    2004 Buell XB12s
