so while out at the lightning kill-tacular session in ennis i had an "issue" that i noticed....
the axle moved in and out the rearend housing when we tried to put the tires back on... broke the c-clip easy fix.... and need an outer seal on the right wheel
well while im in there i figure i might as well go ahead and change out the outer axle bearings when i do the seal.... only 1 problem... that damn thing WILL NOT BUDGE!!!
anyone know how to remove that thing?? i was gonna do both seals and both bearings, but hell if its gonna be this hard i might as well just swap in a 12 bolt (at this point even THAT seems like it would be easier)
so any advice, tips, tricks, tools, sarcasm that you can lend me would help out greatly
