Page 2 of 2 FirstFirst 1 2
Results 11 to 18 of 18
Thread: Line Lock going in today....
    Augusta, Ks
    Sweet so you made it to where it locks fluid from going to the back right?
    2004 Buell XB12s
    Oct 2005
    drinking your alcohol
    correct... lets me use the front pedal to control the roll of the truck
    DamnYankee: my nana failed
    Augusta, Ks
    Yeah thats what im planning to do. that why i askd about pics. What line lock did you use, where did you get it?
    2004 Buell XB12s
    Oct 2005
    i have the B&M launch control, i know alot of people also run the Hurst roll control.
    i got mine at a local speed shop here, but you can find em on summit or jegs
    Spring, Texas
    Let me know how everything went together. I've got a Hurst control kit sitting in a box that I want to put on but not sure which way to do it. I'm thinking about using it to keep fluid in the fronts so I can release the pedal and do a burnout or hold on the line to build boost. Is that possible?? Post up some pics when you get a chance!!
    Oct 2007
    Bandera, TX
    Quote Originally Posted by ramair2002 View Post
    ya, thats how i have one of mine, only prob is the fronts hold and the rears will spin. you need the rear brakes to hold also on the line imo so you can build more boost w/o spinning. i only used the front one with the manual tranny when i was staging to keep me from rollong out. now with the auto just always use the rear lockout to do burnouts. just remember to turn it off... lol, doesnt stop near as good with only front brakes from 120 mph+.... ask me how i know...lol.. its all how you want it.
    single digit street truck
    for build info
    Spring, Texas
    Using the syty shuffle, I can build about 5 psi at the line and not spin. I figured if I had the line lock set up to just hold the fronts, it might be ok. We'll see I guess....
    Feb 2005
    San Antonio Tx
    pics please kthxbai
    02 Chevy EcSb Z71, 5.3, Helix Tb Spacer, AEM Brute Froce Intake, Msd 8.5 wires, NGKTR55 IX, B&M 25k Trans Cooler, Hypertech 160, Nelson Tune, Nelson Harness & Ls1 fans, Fully Built tranny, tb2600, 216/224 551/551 115LSA, yeller z06 springs, magnaflow, cut-out, hi-flow cats, etc...
