look at the dyno run at the top of the thread,,,it has stock hp of 220 at the wheels...dont know chevy's rated hp for the 2000 x 6.0...
'13 silverado LT...stock
'11 lt 4x4 z71..tvs1900
ya it was the 220 that suprised me. I thought factory HP was around 285 at the flywheel for that year. it seems your losing quite a bit of HP through the drive train.
I need to put mine on the dyno to see what the real # are
Jeff
2005 ECSB 5.3
well you guys you have to realize that this dyno is not like the other dynos out there that just free spin the rear wheels so yes his numbers are lower but very close to stock 6.0L . and you also lose 80 hp with the 4l80 trans compared to the 22hp from the 4l60 later, kevin
http://i17.photobucket.com/albums/b9...5831PM-2-1.jpg <--- TimeSlip
RCSB 5.3 N/A 12.31 full boltons,H/C,4.10s,3800 converter. SOLD
04 GTO
Both Tuned By: ME
That is amazing to lose that much HP through the drive train. So if I have 300 HP to start with and about 50 HP in mods, I could only have 270 HP at the rear wheels. No wonder it wont spin the tires!!!
What is it about the 4l80e that causes such a loss![]()
Jeff
2005 ECSB 5.3
its because the 4l80e and the rear ends are so big and are made for heavy duty usage.
Big tranny and rearend kind of bogs it down but i solved that problem.....Turbo![]()
2000 Chevy Silverado 2500 ECLB w/6.0 , 4L80E auto, 4.10 G80, K&N, Nelson Dyno Tune, 02 PCM STS TURBO , 44# injectors, IC ,HPTuner and 160* thermo 348 rwhp, 394 rwtq @ 5 psi
60'=2.241
1/8=9.352@77.39
1/4=14.40@ 96.67
you definetly did that jerry![]()
admin please delete this acct....
yay and i am fixin to be losing some power as well. as soon as i do the 4l80e swap i will have to see where i satnd. i might have to up tha shot a little. i will bne going with a 2800 stall instead of a 2500. i might get lucky and even out with a 175 shot instaed of a 150 shot.
04 supercrew 5.4 3 valve-magnaflow catback
formerly 02denali 12.79@107
I suppose that's the base STS kit, with just the Nelson tune? Right? Don't know if it matters, but did you pick up any mileage with that setup. The article in Sport Truck picked up quite a bit with the base kit, with no engine management tune up.
Yes, 2 mpg city and highway and 3.5 mpg towing an 8500# camper.Originally posted by wkdivr@Oct 3 2004, 08:14 AM
60'=2.241
1/8=9.352@77.39
1/4=14.40@ 96.67
