Results 11 to 20 of 27
Thread: Tru Cool with bypass or not?
  1. #11
    Augusta, Ks
    I think youll be fine. Just keep it running through your radiator too. If your truck is set up like that.
    2004 Buell XB12s
  2. #12
    Lawrence, Ks
    Quote Originally Posted by Warlock2007 View Post
    I will check to see if it is set up like that. Thanks fellow Kansian
  3. #13
    Augusta, Ks
    Welcome. If you have a factory trans cooler then im sure it runs through your radiator first. Thats how mine is set up.
    2004 Buell XB12s
  4. #14
    Jun 2005
    Way up in North Dakota
    Quote Originally Posted by zts gixx View Post
    Anymore thoughts on one with bypass or not? Anyone live in below 30 degree weather without a bypass equiped cooler?
    I have a Tru Cool 28,000 GVW trans cooler with out bypass.
    But Tru cool are supposed to have one [ kind of ] built in it, passageways that send the cold thicker fluid out quicker.
    My temps says lower than what I would like. Rarely getting up to 180 o. In winter I cover the cooler with aluminum foil and cardboard and the temp gets up to about 130 o. This is driving around town. I have it hooked up to the engine radiator like you are supposed to.
    Hope this helps.
    2002 GMC 1/2 ton Sierra,4WD, Xct cab, camed, mid-length headers, Nelson tune, electric rad. fan, trany cooler, Heavy 5750 lbs with topper.
  5. #15
    Augusta, Ks
    Your in North Dakota....we are in kansas. We may not have the problem of temps like you had.
    2004 Buell XB12s
  6. #16
    Lawrence, Ks
    I'm wondering if just going with the bypass wouldn't be the safer route. It's only like $30 difference. Just trying to learn the pros and cons of it I guess. Never dealt with tranny coolers before so thanks for all the input guys.
  7. #17
    Lawrence, Ks
    So the final questions is....do I need a 40k or just go with a smaller one like a 28k?
  8. #18
    Augusta, Ks
    Bigger is better but I just have a 30k with a 10 inch fan mounted to it. That would be plenty. I got a deeper derale pan with the cooling fins and I dont hardly use my fan anymore.
    2004 Buell XB12s
  9. #19
    Jun 2007
    Boy thats weird ,I cant believe ive never heard of such a thing,a bypass in the cooler?wtf will they think of next,?Im goin y is this guy asking about a trans cooler and a throttle body bypass?lol.what a nerd.lol.jokes on me.I guess you learn somethin new everyday.I thought i was pretty knowledgeable.so y do these passages only work when the fluid is cold ?Enlightin me.
  10. #20
    Lawrence, Ks
    Right on. Thanks Warlock
