Results 11 to 20 of 25
Thread: Diggin It In Dallas Texas
  1. #11
    Resize smaller.
  2. #12
    Quote Originally Posted by Fastime09 View Post
    Trying to post pics, but not able, shows they are to large, whats the best way to post...?
    Image hosting, free photo sharing & video sharing at Photobucket
    Make an account, post the pics here with IMG code.
    Welcome to the site.
  3. #13
    Missoula,Montana
    Welcome from Montana
    '00 1/2 TON ECSB 5.3L 4L60E
    K&N Filter,Gibson Exhaust,Superchips Programmer,Billet Servos,'03+ Taillights,White Door Handles,Carbon Metallic Grille Emblem,6000K HID'S
  4. #14
    Richardson
    I think i got it now...Thanks
    2000 sil.ext. 5.3 / Lingenfelter Ls1 cam / LS1 valves / Ported / Milled / 35lb injectors / 80mm tb / E-fans / cold air intake / Pacesetter Cer LT's w/3"ory/ JET-DST / MSD Twister / Corvette Servo / 3.73's / 125 N2O / no cats / Flowmaster exhaust / level rear drop / Rear sway bar / SS wheels / 285/50R20 Goodyears / 05 Tail lites
  5. #15
    SO FAR IT'S BEST TIMES ARE 14.92-MOTOR & 13.86-JUICE... I'M WANTING TO BORE THIS BLOCK AND INSTALL LS1 PISTONS TO BRING COMP. UP AND STEP THE CAM UP TO LIKE 525/ 235...AND A GEAR OF 4.10, HAS ANYONE BUILT A 5.7L FROM THE 5.3L,,, I HERE IT'S POSSIBLE....ANY INFO WOULD BE HELPFUL....THANKS
    Welcome to the site! Nice amount of mods for an old school SBC guy! After looking at your mods, you should have better times than that! First thing--get a custom tune! Second, that cam you have is too small. You can go up to a high 220's duration and high 500's lift with a 5.3L. Are those Edelbrock headers long tubes?
  6. #16
    Richardson
    they are the shorty's & i'v been wanting to install some LT these are not worth the money, i got the cam real cheap but after seeing what u guys are running, makes me want to step it way up, my goal here is to build a 5.7 from this 5.3 and use these heads, at that time step up the cam & other bolt on's....i'v been slowly but surely self tuning with my DST tuner and its starting to come around....these times were ran before the tb, & gear, swap also servo's.
  7. #17
    S.A. Texas
    Welcome. If you are gonna self tune you might as well get HP tunners software. Its way better than the DST stuff.
  8. #18
    What cam do you have again?
  9. #19
    Richardson
    This Cam is based on a 99 camaro SS Grind w/ a hair more lift & dur. & less LSA, ground by Lingenfelter 500/218 on a 116 LSA, not the hottest cam, a little step up from stock, but at this time the engine has 115,000 miles and i can't be to hard on it, when i build it up, then i'm stepping up the cam..
  10. #20
    wichita falls, tx
    nice truck...youve come to the right place...well help you spend your money, i mean well help u make your truck fast
    Intro Radicalli's
