Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
Thread: what stall do I need? TH400 3.42 gears
  1. #11
    9.5" Vigilante FTW!
  2. #12
    Jun 2007
    I had a 10 inch 3k in mine and it was too loose because of the weight of the truck it seemed liike a 4k,not tight at all for daily driving.i think if you go larger diameter itll be tighter .i dont have exp,with pi or yank tho i,i hear theyre not as tight and you can have them made to suit a truck.
  3. #13
    ff_jeff Guest
    I called Redneck perfromance, yes thats their name, and had them custom build me a stall. 2 weeks, they are in stevenvillle, tx. Donald seemed to know his stuff.
  4. #14
    Augusta, Ks
    I just got mine from Circle D today. Its very Nice.
    2004 Buell XB12s
  5. #15
    9.5-10" 3000-3200 with a big cooler won't hurt a thing as far a DD'ing it goes. I'd much rather have a smaller tight 3000 than a loose 12".
