Page 2 of 2 FirstFirst 1 2
Results 11 to 17 of 17
Thread: Front noise
  1. #11
    There is more than one front hub. Most times choosing which side is a crapshoot unless your choices put food on the table. Don't fret. I hope you have the bearing that came off. Put it on the side that has not yet been replaced. If that makes it go away you did the job twice but only paid for one new part.
  2. #12
    El centro, Ca.
    I can hear where the noise is coming from when I put my head out the window.
    2005 Silverado 4x4, 6" RCD lift, M/T Classic locks on BFG KM2's, 4:56 gears, Air-raid CAI, TB spacer, Nelson tuned, Corvette servos, 160 thermostat, Ebay long tube headers, Flowmaster Delta 40, Cognito Motorsports steering upgrades. 2000 Ford Lightning, 2.3 KB, bolt ons, 7.67 on the 1/8th.
  3. #13
    Augusta, Ks
    Have you looked over your tires? Loose center cap?
    2004 Buell XB12s
  4. #14
    Wasilla, AK
    Quote Originally Posted by Silverado05 View Post
    2001 ECSB 4x4, 5.3, Radix, 3.0 pulley, VHP Trucker cam, 216/224 .551/.551 115 lsa, 1.8 Crane roller rockers, 4L65E, Yank SC3000, 3.73, Cal-Tracs, HPTuners.
  5. #15
    Jun 2007
    It wouldnt happen to be the famous backing plate.they bend very easy.
  6. #16
    El centro, Ca.
    I almost killed myself, lose beadlock bolt!!!
  7. #17
    Augusta, Ks
    Knew it had to be something simple. It usually is.
    2004 Buell XB12s
