Results 11 to 20 of 27
Thread: Hydrobooster
    Oct 2007
    Bandera, TX
    i need more info on this for sure. I think this will fix my problem of pushing through the brakes while trying to build boost.
    single digit street truck
    for build info
    Quote Originally Posted by TurboMic View Post
    Thunder550 did the hydobooster conversion mic, you can ask him as well about his setup
    Austin, TX
    It's so easy to convert to hydroboost. it will hold at idle with no vaccumn in engine. need p/s pump, new p/s lines and may need a different brake pedals. You will love that you just tap the pedal to complete stop.
    5.3, E-fans, LPP longtubes w/offroad Y, Dual Magnaflow, K&N Cold Air, 160 thermo, Voodoo 212/218 .531/.531 113 cam, Nelson Tune, 4:11, Built 4L65E, TrailBlazer converter. SOLD
    _____________________________________
    2006 2500HD 6.0L Crew Cab 2WD
    Quote Originally Posted by Jermoslin View Post
    lol well there you go mic. Once I get the money im def. upgrading to hydroboost
    Apr 2005
    DBRODS does these conversions. Kurt had this setup on his GMC.
    Gone, but not forgotten!
    S.A. Texas
    My bro- inlaw just did this on his bagged CC he said the loves it, said it was pretty easy.
    we need a write up for this cause i'm interested in doing this too when i can get the money up need a list of what all is needed to do it because even my awd barely modded truck pushes past the alumasports trying to stall the truck up
    [Today 11:15 AM] MidnightRider: justin= generalvehicles.com moderator
    Blue Springs, Mo
    Quote Originally Posted by ss wrecker View Post
    I got a write up saved on microsoft word if anybody wants to do a sticky on it?
    2004 silverado rcsb 2wd cammed 6L, 3.42's, Hydroboost swap, 4l80e w/hd-2 and yank 3200, twin intank pumps, 60lb injectors, trick hot pipes/MP T76
    Oct 2007
    Bandera, TX
    i will do a write up when i do mine. Im doing alot of research on it. I think I have most of the parts ordered already.
    for build info
    Austin, TX
    All you guys need is a pump and two high pressure line and then some bulk vaccumn hose for the return. maybe a different pedal. Or get the vin off of a 2500 and order parts for that vehicle. It all bolts in and works. You may find that the booster bolt pattern is different then your firewall. You can remove one of the studs or drill a new hole in the firewall.
