Results 11 to 20 of 29
Thread: Garage cleanout, Maggie, whipple, duramax
Threaded View
    Oct 2006
    Wichita Falls Tx.
    Started cleaning out the garage and have a few things that need to find home elsewhere. Some new some used but all good parts, if you see something you like let me know.!
    This is a BRAND NEW 122 MAGNACHARGER
    Never been install.
    Comes with everything new in the box.
    DAUL heatexchangers
    90mm J tube
    90mm throttle body
    Booster pump
    4200+ freight + paypal.
    Dual heat exchangers.
    All accessories are still in their packaging from Maggie.
    Blower still has the inspection tag on the fuel rail.
    90mm throttle body included.
    Next is a whipple off of a 99 5.3
    This is a used unit, was traded in on a turbo kit.
    all the electronic, space belts, 2 pulleys, injector computer etc, instruction manual all in tact.
    1500.00
    05 Duramax complete, turbo, front drive accessories and the harness. Harness did not get cut until the rear area of the truck. Engine is a take out and ran just find. This would make a good replacment or if your into diesel hot rods a great starting platform.
    4200.00 +freight
    Online Store
    [/CENTER]
