Results 11 to 20 of 35
Thread: debadge
  1. #11
    Birmingham, AL
    this all sounds easy enough. ill try it in the next couple days
    01 Silverado
  2. #12
    Or a thumbnail works too....it's free. Set aside 6 hours.
  3. #13
    May 2006
    Waco TX
    Quote Originally Posted by mean05 View Post
    lmao yeah that makes it a little easier and that eraser wheel is well worth buying, it just goes in the end of the drill and saves you a lot of heartache, i take these things off when i have to letter trucks and i have tried every known way
    If you put the eraser wheel in the drill do not turn the drill on high speed. The wheels are only rated for a certain RPM and I have seen the fall apart before when put in a drill.
  4. #14
    mine came with the factory with no badges, makes things easy
    Oct 2008
    West Columbia, South Carolina
    You may want to try some braided fishing line (Stren Superbraid, Spider-Wire, etc.). It will have no stretch like monofilament (sp) and the "wound" fibers of the braided line will actually have a better cutting or serration action between the emblem and foam backing.
  6. #16
    San Antonio
    1. just pull badging or moulding off by simply peeling it off. 98% of the sticky tape came off with it when I did it this way.
    2. spray a little WD40 on a rag and wipe off any other tape or residue.
    3. wash truck, you are done.
    Let me tell you what Melba Toast is packing here allright............
  7. #17
    wichita falls, tx
    u havent done this yet?...lazy
    Intro Radicalli's
  8. #18
    Birmingham, AL
    Quote Originally Posted by banker099 View Post
    im back home for christmas, and it was raining every day until i left. but it will happen!!!
    01 Silverado
  9. #19
    Birmingham, AL
    well, i finally got around to doing this today. i also washed it and changed the oil, so my truck likes me alot today!!!
    BEFORE:
    AFTER:
    I also moved the antenna under the hood...
    01 Silverado
  10. #20
    Austin, TX
    Cleaned up well. Nice work!
    '89 RC Step-Side - 383 Stroker, Belltech 2/4 drop, Escalade Nose
    '02 Tahoe - 22' Rims and a Custom A/V System
